Steam Not Making It Though
Concerned Apartment Owner
Member Posts: 47
Hi All, Our building needs help trouble shooting a problem. High rise in NYC. Two pipe system. Steam not making it through radiators on one riser. Plumber is at a loss. This line was recentl cleaned. I was told line was full of dirt. What is the best way to find to problem? Is it possible the steam traps were clogged in some way during the cleaning process.
traps
That would be a good place to start. Check them all and blow down any strainers. Hard to say otherwise without seeing the layout.0 -
CALL A LICENSED PLUMBER
you got the wrong plumber. a competent plumber would solve the problem , period.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
