Noisey Radiator
Mark_93
Mark_93 Member Posts: 1
I have a one pipe steam system - 16 radiators total on 2 levels. One radiator on the 2nd floor sounds like it is a coffee percolator when the steam is coming on. It never did this before, but just within the last few weeks whenever the steam comes up it gurgles and churns like a coffee maker. The vent is clean, the radiator is pitched toward the supply pipe for proper draining and the service valve is fully open. What would all of a sudden make this radiator noisey?
  • Vermonter
    Vermonter Member Posts: 57
    Sediment?
    Could be sediment that shifted to the supply valve...
  • chuckNJ
    chuckNJ Member Posts: 40
    last take off?
    Is it by chance the last radiator on the main before it turns down to the wet return? If so, this could be a sign of condensate beginning to back up into the main due to a slow (clogged) return. If so, you might also observe the water line at the boiler dropping lower than it used to during the early portion of the heating cycle.
    W-M EG40, 235 sq ft edr, one pipe
  • mark_94
    mark_94 Member Posts: 1
    It is the last riser on a branch off of one of the mains beyond the point where the dry return for that main drops down. Bascially I have two mains that run non-counterflow to either end of the basement where they then drop down into their respective dry returns. Then some counterflow mains branch off of those primary mains and run out under crawl spaces with various risers coming off of those. This subject riser is the last one off one of those counterflow mains under one of the crawl spaces. The radiator on the first floor (below this subject radiator and fed off of the same main) does not have any issues. The first floor rad is peaceful and hot. The second floor rad above it sounds like coffee maker. (it gets hot too, but it just makes a racket)
