Anode rod for Chlorine?
Larry Weingarten
Larry Weingarten Member Posts: 3,989
... want to put the anode in the center of the copper coil to get even current distribution. The anode could be plain steel (connected as Larry C says) though it might make the gray water grayer ;~) Can we assume the tank is plastic?
Yours, Larry W
