PRODUCT ADVICE FOR NEW INSTALL WHAT WOULD U DO??
Good system ideas but the first step is to do an accurate heat loss to determine what amount of heat you need to deliver. 12" on center may/may not be enough BTU/sq. ft. Bubble wrap may not be enough insulation and yes, transfer plates are a better way to go, especially the aluminum type. You can get more BTU's from less temperature using the extruded plates. Go with a condensing boiler and use and indirect for hot water. Why have two pieces of equipment when one will do the job.
  • dmy hvac
    dmy hvac Member Posts: 33
    advice
    looking to find out what people would use in my situation am having a modular home built and will arive april first i have installed maybe 15 boilers my whole life half of them were in floor heat i do mostly commercial refrigeration but am gonna install my own boiler was planning on having propane cause natural not available could get fuel oil but not a big fan of it.im gonna do in floor heat the basement will have pex r onyx in slab tied to mesh is 4 inch slab o.k.? and was gonna have 5 zones upstairs with onyx stapled under floor bout 12 inch apart with foil bubble insulation under it stapled to floor joists.are the metal heat transfer plates a better way??also was wondering bout having a boiler mate water heater hooked to boiler is a seperate tankless (propane) water heater better so i would not need to use a mixing valve to regulate in floor heat temp could just keep boiler at lower temp and what temp is best for tubing 120? or i could use one of those taco injection controls with pump.is zone valves better for each zone or pumps.looking to hear what people would do r use if this was there own home 1540 sqft raised ranch thanks.
  • dana_6
    dana_6 Member Posts: 1
    HEAT
    thanks for info. if i go with in direct water heater then i will have to have a mixing valve of some kind cause i cant run indirect with 120 degree boiler temp. what exactly is a mod con boiler? ive never installed one can it be pvc vented? thanks for any advice also what brand of boiler would u use?also what would u use to regulate water temp going to in floor?are the advanced outdoor temp and water temp sensing controls the most efficient way??
  • Ragu_5
    Ragu_5 Member Posts: 315
    Dana...
    Al gives great and honest advice; I agree with him. Perhaps you could hook up with a Heating Pro in your area, and swap some technical hands on work to iron out the remaining issues. I respect both trades. Jack
  • Mark Hunt
    Mark Hunt Member Posts: 4,908
    Dana
    If you have never installed a modulating/condensing boiler, I would recommend that you find someone that has. These are NOT like anything you have installed before and require digital combustion testing equipment for proper start-up.
    That being said, most mod/con boilers vent with PVC although there are a few that do not. They require special venting material available through the manufacturer.
    You would not need a mixing valve to lower your radiant supply water temps(assuming all zones require the same temp) since the mod/cons will prioritize the domestic water heating zone on a call for heat. Once the domestic is satisfied, the mod/con returns to space heating mode and what little high temp water is left will be cooled very quickly. No adverse affects on the radiant zones.
    Also, most mod/cons come with some form of reset built in. This means you can program a heating curve into the "brains" of the boiler and it will adjust the temperature of the water going out to the radiant zones. This prevents "over-shoot" of the temperature in the space and it lowers your fuel consumption. Much better than thermostatic mixing valves!
    The "mod" part maens that the boiler modulates it's firing rate according to what is needed. This is different from the "on/off" boilers you are used to. Again, this lowers your fuel consumption.
    The "con" part means that the boiler is condensing. It will condense when the water temps required stay below 130° for LP. You are pulling more heat out of the flue gas rather than letting it go out the exhaust.
    I doubt that your slab zone will ever need the same temp water as the Onix staple up so you may experience some over-shoot in that zone. You could use a TMV for the basement zone set to limit the water temp to say 80°.
    I have used both the Onix and the aluminum plates. The plates raise the initial cost a bit, but they work like a champ. Not that Onix doesn't work, I have it in my house. But if you are doing the install yourself, spend the money and go with the plates. We use Uponor's plates with 3/8" HePex. Goes up faster than you might think.
    Regardless of which boiler you decide to use, it is VERY important that it be tested with digital testing equipment upon start-up. it is the ONLY way you will know if the boiler is burning properly AND safely.
    Hope this helps!
    Mark H
  • dmy hvac
    heat help
    thanks for all advice. didnt realize mods were so advanced are all the high efficient boilers that way r can i get away with a pvc vented boiler that does not require such a precise combustion test?also u mentioned that temp be at 80 in concrete is that max temp?another stupid question can u use onix with the plates cause onix seems much easier to work with or is way to costly?thanks for all your advice.what brand boiler do u recommend???
  • Doug_7
    Doug_7 Member Posts: 266
    Dana - Make sure you put the proper insulation under the concrete slab before you pour the concrete or you will be trying to heat the whole world. Big waste of energy.
    Typically use 2 inches of Styrofoam extruded polystyrene foam. Do not use polystyrene bead foam because it absorbs water and loses it's insulating value.
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,670
    Dana...............
    As much as "they" want to promote plug-n-play technology, it is more imperative than EVER to understand the equipment you will be installing. The boiler is a given - proper installation is not. Pay a pro to consult with you on this and you will not regret it. Someone proficient in combustion analysis and advanced piping strategies. Mad Dog
  • dmy hvac
    reply
    thanks for advice but looks as if i'll be going at it alone.the company i'll be buying the boiler from will do the sizing and there pretty trustworthy.i didnt really realize combustion tests for propane have become or are so important other than checking the gas pressure ive never heard of anyone doing a combustion test on gas r propane or is that just for the newer mod con boilers?thanks for any future advice you can give me on this matter it is greatly appreciated
  • Install photovoltaic roof. Hook the solar electricity to a 60 gallon electric water heater then use 2 or 3 stone lined indirects as the battery
  • Jeff Lawrence_25
    Jeff Lawrence_25 Member Posts: 746
    Doug
    That works where you are, but we can't use it here. We have termite problems and the extruded polystyrene is like a super-highway for them, complete with an engraved invitation...
