commercial boiler air vents on glycol system
spyderco
spyderco Member Posts: 3
I'm running a glycol hot water system with 3 Sellers 150 psi boilers. The problem I'm having is with the air vents. They are equiped with spirax sarco ty-2 (13w) vents that don't seem to be allowing the air to vent off the boilers. I'm curious if these are the right vents or should I be using somthing different.
  • Ken_40
    Ken_40 Member Posts: 1,310
    Always check
    the manufacturer's literature to be sure the pressure ratings are within your needed range.
    Don't have my S/S catalog handy, but sspect you may be onto the cause.
    Location of vents is even mnore critical! I wish I had a dime for every vent I saw on a pipe elbow/tee. Wrong, wrong and wrong way to go.
