conversion formula
Brad White
Member Posts: 2,399
"which weighs more, a pound of gold or a pound of feathers?"
A. Gold.
A. Gold.
"If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad
cu/ft = gallons
any one know how to convert cubic feet into gallons???0 -
Here you go
X.XXX (edit) 7.481 gallons in a cu ft or 1 gallon is 0.1337 cu ft0 -
Not for nothing, maybe a typo
my table says that there are 7.48052 gallons per CF, call it 7.481.
Your 0.1337 (0.13368 by my chart FWIW)
is correct, so I suspect a typo inverting the 1 and the 8.
The volume is at 68 degrees by the way, so if you are storing hotter water you may have to correct things, but if you are that close...."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
You sir are correct
Nothing like transposing numbers to fowl up the works0 -
I know you, Bruce
and you would never let that stand. I tip my hat to you, sir!
Brad"If you do not know the answer, say, "I do not know the answer", and you will be correct!"
ah oh brad????
volume at 68F??????????????
a volume is a volume is a volume!!!!
a gallon is a gallon, which is of course is also a cu ft, cu inch , cu meter..etc.... milliliter
now if you are converting gallons to pounds or kilograms that then would be a temperature story.0 -
The volume of water changes
with temperature, JP. More accurately, it is the density but volume and weight are so interdependent that way.
If it did not change, then gravity hot water systems were a major hoax
I see your point in the absolute, but volume is relative to temperature when comparing different substances.
If you filled a cubic foot container made of one material with water at a hotter temperature you would feel short-changed when it cooled. It would be smallest in volume at about 39 degrees F. (4 degrees C.) So one always needs a temperature reference when measuring volumes of anything, gasses, liquids and less affected, solids.
Anyway, my table stipulated the temperature factor, FWIW"If you do not know the answer, say, "I do not know the answer", and you will be correct!"
word games
of course I agree with density changes vs temp Brad.
but if you read the question without any assumption, then 4.32 gallons of 200F water will have the same cu ft as 4.32 gallons of 33F water. just don't alter the temperature!
kind of a trick question if you disect it
weights, densities and volumes can be tricky when mixing water & alcohol!0 -
Converter
Reminds me of the question "What is heavier, a pound of lead or a pound of feathers?" Both measured at 70F of course.0 -
Hardly...
but you started it!
The physics involved transcend words regardless of our wishes...0 -
i'm missing it,
pls explain?0 -
A pound of gold
is measured in Troy Ounces and if you are lucky enough, Troy Pounds. We use the Avoirdupois system for most commercial measurements but Troy is used for precious metals.
A Troy Pound is about 0.83 Avoirdupois Pounds.
There are 12 Troy Ounces in a Troy Pound, so if you are talking about ounces of gold or feathers, all bets are off. A Troy Ounce is about 10% more that an Avdp. Ounce.
No whining now! I told you it was a trick question...
Love it
Brad.
You are so much better at this than I. Will you write my next rebuttal?
Jack0 -
Thanks, Jack
But trust me, you do not want me to write responses to unreasonable change orders....
I appreciate your support and comraderie!
Brad0 -
online conversion
Was is 8.33 or 2.31 or 3.14 or 2.54 or 7.48 or 2.2 or....oops we missed Mars.
Doesn't help much with gallons per cubic foot though.
WWW Unit Converter0
- 167 Indoor-Air Quality
