baseboard heater
mary_7
Member Posts: 1
so the wind storm recently has created a horrible noise in only my baseboard heater in my bedroom. It sounds like a bee magnified by 1000. when the wind picks up thats when you hear it. any thoughts or suggestions as to what happened and what i can do to fix? thanks
MEGA infiltration issues...
Air blowing through a baseboard heater shouldn't affect the water side of the system and cause it to make noise. Using an incense stick, see if you can "see" where the air is entering the home. Once you find it, plug it (either inside or outside the home) and your noise, discomfort and cost of heating should get better...
ME0
- 167 Indoor-Air Quality
