Recommended Aquastat Setpoint
T.W.
Member Posts: 5
We recently replaced Tankless on oil fired hot water boiler with indirect Weil McClain Gold Plus 40. Boiler has Honeywell L8124A 1007. High set at 180, low set at 160, and differential is approximately 15. Should the aquastat set points remain? Open to suggestions for relationship to efficiency. DHW maintain approximately 125-130. System operating fine, customer satisfied.
Refer to cold start posting
Look at the cold start posting. You should find information about your situation there.0
- 167 Indoor-Air Quality
