Nice and Clean job photos
ScottMP
Member Posts: 5,882
photos of our job. After it was all wired and cleaned up. Still hav'nt insulated yet but after seeing Pauls job I now have a different idea of what it should look like.
Scott
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=237&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Scott
Awesome!
Other the leaks all over the press fitting o-rings, that's knock-dead gorgeous!
Nice looking
job scott! Keep up the great work!
P.S. Don't give Paul to much credit for the Insulation job. His head probably will not fit through the next mech. room door. After all he suggested that he was going to insulate the rad. that I made for him? again great job!
Matt w/Biggerstaff rad. solutions0 -
is that...........
a caleffi hydraulic seperator on your job?, If so, can you give me your opinion on it. Did it make your job work better? Was it worth the investment, would you use it again?...............Very nice looking work, a job you should be proud of.........0
- 167 Indoor-Air Quality
