kitec
does the inter liner of pex al have ox barrier?
  • Jeff Lawrence_25
    Jeff Lawrence_25 Member Posts: 746
    I beleive
    The aluminum liner is the barrier.
  • mark_41
    mark_41 Member Posts: 48
    kitec orange failure in seattle
    kitec orange has 3 layers, does the inner liner of plastic reain have ox barrier? We have installed an open heating system and the pipe is failing. It is undserstood that this type heating system has many short commings, however my question is should that be an excuse for the failed pipe?
  • ALH_4
    ALH_4 Member Posts: 1,790
    how
    How is the pipe failing? Is there any possibility of exceeding the temperature and/or pressure rating of the tube? The fact that it is an open system should have no effect on the tubing.
