ground source heat pump hot water
just pipe the 4 heat pump circuits in parallel w/check valves on each circuit. depending what heat pumps you're using (most desuperheater heat exchangers are double wall for direct potable connection) you could connect directly to the storage tank without using a coil.
Can anyone offer me suggestions on how to pipe 4 ground source heat pump desuperheaters to one 162 gallon vessel. The vessel contains two heat exchangers,I am hoping to install 1 heat exchanger to a future solar source, as well as additional ports to the tank itself. Thanks for any input0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 962 Plumbing
- 385 Solar
- 15.3K Strictly Steam
