blow off is very slow
Karl_10
Member Posts: 2
Blow is working very slow
the blow off is working slow0 -
slow blow
do you mean the drain from the boiler, or the low water cut off is slow.
if it is the low water cut off, then i recommend getting a pro in for service, as it may be unable to prevent your boiler from dry-firing, and destroying boiler, and building with it! if it is the boiler drain itself, then that is a problem which can wait for warmer weather, to "clean out the mud legs"; although it could save fuel to have it done sooner. --nbc0
- 86.8K THE MAIN WALL
- 56 Biomass
- 107 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 954 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
