corn boiler
hr
hr Member Posts: 6,106
would not work. Like any boiler connected to a low temperature radiant system, you need to pipe in a boiler return protection method.
A buffer may not be needed if the corn feeder modulates the output somehow. I believe some of these feeders have variable speed motors? Or pulse the fuel to the heat demand. that should be a simple control to incorporate.
It will also depend on how close the boiler output matches your actual load.
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • CARY GILLIS_2
    CARY GILLIS_2 Member Posts: 1
    CORN BOILER
    Anybody ever install corn boiler for radiant, say maybe with a buffer tank
