TXV Bulb tightness?
Eugene Silberstein 3
Member Posts: 1,380
The bulb should never be installed on soft-drwan tubing.
No matter how you try, it will never be perfectly straight.
Bulb Tightness
Hi all
How tight do you get your txv bulbs?
I double checked one Fri and could move the bulb thru the insultube. Removed insulation and redid straps. You can not move the bulb now! Am I being too picky or what?
Thanks
Don in Central Mo0 -
Right Tight?
Your new "tight" is NOW right.You are not being picky ,you are being "normal".0 -
If you can wiggle it....
If you can wiggle it, it's too loose.0 -
Don't forget
Clean and tight....Make sure there is no corrosion on the surface.
Mike T.0
- 15.8K Strictly Steam
