steam to water boiler conversion
Steamhead (in transit)
Member Posts: 6,688
are that the radiators might not be big enough to heat the house with hot-water, and there's a good chance they will leak under the increased pressure a hot-water system needs to operate- at least ten times the pressure a steam system needs. I've seen converted systems that leaked all over buildings- this is one reason we don't do these conversions and will not work on a system someone else has converted.
You can achieve the same efficiency and control on a steam system for far less money than a tear-out/repiping. Newer steam boilers are far more efficient than older ones. And a steam system is far less likely to freeze up in an extended power or fuel failure like a hot-water system can.
Your best course of action is to keep the steam.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
I am renovating a 110 year old,3500 sq ft house that has cast iron single feed radiators hooked up to an old gas fired steam boiler.I am wanting to convert it to a water boiler with zone valves to each radiator for efficiency reasons.I am planning on running new copper supply & returns to each radiator.My question is can the steam radiators be converted to hot water radiators,thanks.0 -
- 110 Chimneys & Flues
- 979 Plumbing
- 387 Solar
- 17 Recall Announcements
