Feasible
Weezbo
Member Posts: 6,231
Feasible? Input?
To be both cost effective and fuel efficient I am putting together an in floor system with a domestic water storage tank used as the buffer tank on the primary side. On the scondary side I will have four lower temperature in-floor zones utilizing their own pumps and tempering devices to meet temp. requirements. Munchkin LP boiler and most likely a Triangle indirect. Any red flags or advice?
Thanks in advance!
MP 19690 -
Perhaps I'm being dense...
.... but why the buffer tank with a low-mass condensing boiler? Wouldn't it make more sense to take advantage of the modulation feature to provide the right water temperature to the primary loop, as indiecated by the pri-sce piping that HTP likes to spec, IIRC?0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
