Goofy Insulation Question
Mike T., Swampeast MO
Member Posts: 6,928
Could Insultarp be used on top of an attic floor in an old house? Either alone or perhaps as a carpet pad?
Someone at another forum is looking for ideas that don't involve either removing parts to blow in insulation or adding a insulated false floor on top.
This is a little...
...bit outside my normal area, but might it act as a vapor barrier? Might that cause condensation (read trouble)? Just a thought.
Yours, Larry0 -
Vapor barrier
Vapor barrier (or tarp, in this case) should against the warm side of the floor/ceiling.0 -
Depends...
Mike, where's the house?
We shouldn't automatically assume that it is a "northern" house. If they A/C more than heat then the vapour barrier should be on the outside.0 -
Not sure where it's located. Will try to find out. Just an odd idea I had.0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 111 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
