boiling radiator
thfurnitureguy_4
Member Posts: 398
I have 2 American radiator Co 2 column radiators that were just added. I noticed that they both boil while full of steam I added a 1/2 inch to the legs away from the valve and they still boil. is this because its not really that cold yet, and the room is not cooling the rad ?
Did you put fiberglass insulation on the supply pipes to the radiators?0 -
No. My supply comes from the celing, blows down through the floor, Ts over and than back up to the rad. The drip past the T goes to the wet return. I was going to leave The supply exposed for more radiation like the others in the building (that dont make any noise) What am I missing?0 -
Beano is for rumblings
One pipe radiator, I think?
Is the valve either wide open or wide shut? Anywhere in between calls for gurgling.
Rusted valves don't easily open all the way. Tear them open to take a look and clean them up.
Another idea.
Check to see also if it isn't a pile of dirt that is restricting the return flow. Your tilting the radiator might have shuffled a lot ot dirt towards the intlet.0 -
It's not Jay, am I eating your cookies, Invision help needed
I noticed this last post by me went under a different name. I don't understand were the mix up comes from.
Is there any explanation for this? Am I doing something wrong?
Sorry and thanks.0 -
Valves new and open wide, yes a 1 pipe system, flashlight look shows no obstruction. A question. If the opening where the valve goes has a bushing, won't it fill up with water to the spill leavel of the spud? These rads came with a 1.5 to 1" bushings. I did change them it to a 1.5" to 1.25" bushing. I would think it would now have a lower water level inside. Perhaps less water boils quicker?0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 112 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
