Buderus Indirect
Joe@buderus_2
Member Posts: 302
The ST tanks are no longer sent with an electric anode, it is now a magnisium rod. The switch was due to failing to supply the electric anode rod with a power source and the tank failing. We do offer the electric anode rod a option which has to be purchased seperately. Thanks
I understand Buderus no longer supplies electric anodes for their "ST" series tanks although the on-line literature states otherwise. Is this now an option? Thanks.0 -
Yea whats up with that?0 -
Rod Inspection
Joe, how do you gain access to the rod? I did not notice any rod taps? Do you need to pull the access hatch ?0
- 120 Geothermal
