reverse return
Dan C._2
Dan C._2 Member Posts: 54
Could I pipe cast iron baseboard using a manifold at the boiler and setting the minifolds up the way you would pipe a reverse return system and expect it to work the same?
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,646
    Yes.
    And I like the word, "minifold." If that was just a typo, thanks for the inspiration.
    Retired and loving it.
  • Brian (Tankless)
    Brian (Tankless) Member Posts: 340
    Cutely deliberate
    the "A" is a 100 miles clear across the keyboard from the "I".
    I like minifold , too.
    Isn't "minifolds" another name for the "pleats" in small Irish Kilts :)
    Off to work. Rita did some serious damage around here.
    Brian, in treeless, roofless, & homeless Swampland. (photo's when I get time).
    Anyone need oak? we've got millions of board feet just lying around.
  • Dan C._2
    minifold
    was a typo. sorry.
