Copper in sream
Just what properties of copper , attack the boiler in a steam system . (steam side)
  • Al Letellier_9
    Al Letellier_9 Member Posts: 929
    copper in steam
    Not so much a properties problem. Electrolysis can occur between dissimilar metals. Constant expansion and contraction of piping can work on a copper sweat joint and it will weaken over time. My main complain about seeing copper on a steam boiler....laziness !!! Take the time to set up the gear and do it right.
  • gerry gill
    gerry gill Member Posts: 3,083
    the fact that it acts as a cathode
    in relation to the iron which will become the anode in coppers presence. http://www.eaa1000.av.org/technicl/corrosion/galvanic.htm
    gwgillplumbingandheating.com
  • Anna Conda
    Anna Conda Member Posts: 121
    As the steam erodes the copper and carries little particles away, they can settle in the system, even back in the boiler, and voila - a hair-tearer of a galvanic problem because the source isn't obvious.
  • Chris_82
    Chris_82 Member Posts: 321
    Copper is great...
    just not in steam systems. There are multiple posts and threads regarding copper and steam on this site. You can do a search and see much more than what is here. Again the constant movement anneals the copper making it much more likely it will crack in a circumferential pattern. And copper as all materials subject to vibration and expansion, moves a great deal. It is a cheeap way of saving a buck at the customers expense and just cheapens the trade as well.
