Iron in hot water boiler
Richard Ortlieb
Member Posts: 2
I have munchkin hot water boiler with a pex radiant system, the system is full of iron from the well water that is at this house.we have put in a high end water system and softner to correct the hardness of the h2o,but does any one have an idea on what I can put in this boiler to clear out the brown iron in this system,someone said to use T.S.P. THANKS Rich Ortlieb.
I have munchkin hot water boiler with a pex radiant system, the system is full of iron from the well water that is at this house.we have put in a high end water system and softner to correct the hardness of the h2o,but does any one have an idea on what I can put in this boiler to clear out the brown iron in this system,someone said to use T.S.P. THANKS Rich Ortlieb.0 -
I'm not sure what is the best way; but
water softning does not normally take out iron very well. You probably need a green sand filter; and it will need to be cleaned or have the media replaced once every few years.
Perry0
- 167 Indoor-Air Quality
