Lochinvar Solution..........
hr
Member Posts: 6,106
over the older version fin tube boiler. I have one installed, Gotta love the simplicity of a basic boiler, sometimes :)
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
hot rod
Any input on this boiler?
I'm pondering using one for the barn job I posted about a few days ago. The two stage feature would dovetail nicely with the system that will be in place along with the addition of a small buffer.0 -
Steve
If budget is the key to the HO, this is my atmospheric boiler of choice. I love the 2-stage firing, integral combustable floor-shield, and PCB for optional outdoor reset. As with any low-mass boiler, flow through the HX is key, I like y-strainers on the inlet. The terminal pad is easy to wire and has terminal screws for a flow-switch, which I really like.
Solid, dependable little package.
Regards,
PR
Which boiler? Knight modulating?0 -
Solution
is different than the Knight. The Solution is a copper fin-tube atmospheric non-condensing boiler.
The Knight is a sealed combustion mod/con with a Stainless-Steel HX, outdoor-reset, DHW contacts, BMS contacts, and a bunch of other features.
Regards,
PR
- 120 Geothermal
