Parallel primary loop?
subcooler
Member Posts: 140
I have a conv gravity system I am replacing, and it has three zones out from the boiler room. Since all zones are the same heat demand, would a parallel primary system using crossover bridges be better suited? With the primary loop @ 5gpm, how is the balancing valve (flow rate) figured for the crossover bridge?
Thanks, TimJust a guy running some pipes.0 -
Is there not much benifit to using this piping method vs. regular p/s?
parallel primary loops
Tim,
My opinion on parallel primary loops has changed in the last couple of years. You can achieve the same benefits (equal supply water temperature and hydraulic separation) with a hydraulic separator, and eliminate the need for a primary circulator. Sample drawing attached. See the Hydronics Workshop column in the upcoming November issue of PM for more details.
Siggy0 -
HC
Hydraulic Separators, they are neat.
Siggy
Isn't the boiler circ in your drawing in effect becoming the "primary circ"? So really you're making the circ serve a dual purpose?
PS: I agree on the LLH/hydraulic sep concept. Much easier and less piping than two pipe pri/sec. Wonder where that idea came from?0 -
Whose brand of hydraulic seperator do you recommend??? A very new concept to me. But I am willing to learn.
MP19690 -
HC
Two that come to mind are Caleffi and Viessmann.
This is a very new concept to me as well...was going to just go p/s, but thought the parallel primary loop looked like a interesting option. When one CI boiler is used, and all 3 zones want equal heat, is there a need to go p/s or would 2-pipe direct return w/ boiler bypass be the ticket? Am planning on seperate circs for the zones, not zv's. Piping is a small loop, not large enough to need reverse return.
Thanks a million,
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
