Banging pipes
Steamhead (in transit)
Member Posts: 6,688
a one-pipe or two-pipe system?
steam pipes
HI,
A little help.
Steam system. Changed radiators to steel fin tube. New vents on all. Insulated pipes all basement.
Changed prestrol to vaporstate.
Problem; Only on heat up of over 5 degrees ie 60-67 the pipes are banging. It seem the condenstate is not making it back fast enough. Set presure at 2oz and 0 diferential. Just seems to cycle too fast . Termostat is set for steam.
Someone told me I have to add backflow protector on retrun for vapor stat.
Any help please.
John0 -
one pipe system0 -
Steel fin tube
How long are the sections of fin tube. I've always found that if you go farther than 6 feet on standard 1 1/4 steel fin tube section, you will have problems.
Anthony0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
