ventless propane fireplace
JackFre
Member Posts: 225
For replacement heat I'd recommend the Rinnai Energysaver. If you go to www.ductlessheat.com you can view the product and do your own heat loss. You will not be disappointed. Do not oversize the unit. Depending upon the size/configuration of the house a mini-split A/C. Wait until spring and all the inverter based 21 seer units will be out.
Ventless propane fireplace heating whole house
I'm buying a place in a small town in California that has a ventless propane fireplace as it's only source of heat. Using a ventless fireplace is illegal in california so I'm wondering what a good substitute would be? Would a standard wall heater be a good alternative? Is electric baseboard heating too expensive?
Thanks,
Jim0 -
Direct vent
wall furnace or fire-place. Only you and your electric bill can decide. Need AC? What about a heatpump? Maybe a ductless mini-split for a small open floor plan house.0 -
How big
is the house? Does it have a basement? Where in California?0
- 87.2K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
