\"Stupidity\" wins again
read my post about "Periodic TT Solo Backfires", one of these units was my own.<BR>As I posted, Greg & Guy emailed me with instructions of what to check, so <i>"going-in"</i> I gave it a try.<BR>Long story short, I tried to "adjust" the wrong piece & it busted. Ever have <i>one of those days?</i><BR>Anyway,, I prepared a pdf of the things on the igniter that should be checked if you have a similar problem(it`s NOT in the manual), so the same thing does not happen to you!<BR>Unfortunately, I learned the <i>hard way.</i> <BR><BR>I hope this helps!<BR><BR>Dave
Now THAT
is a picture worthy of a proper manual... Good going, Dave, you probably prevented far more occurrences.0 -
Thanks for taking the time to share.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
