Insulation of steam pipes
you can get a lot more thickness but at slightly less R-value per inch.
But it will look like crap. No matter how good you are.
  • bill_105
    bill_105 Member Posts: 428
    Is it safe to use regular fiberglass batts or roll (wrap it around the pipe, then tape) to insulate steam pipes instead of the "pre-formed pipe" fiberglass. I know it would be more work.
    "Spend money to save time, or spend time to save money"
