Insulation of steam pipes
Brad White_203
Member Posts: 506
you can get a lot more thickness but at slightly less R-value per inch.
But it will look like crap. No matter how good you are.
Is it safe to use regular fiberglass batts or roll (wrap it around the pipe, then tape) to insulate steam pipes instead of the "pre-formed pipe" fiberglass. I know it would be more work.
"Spend money to save time, or spend time to save money"0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
