Riser Insulation??
brucewo1b
brucewo1b Member Posts: 638
they can match that couch with velcro coverings
  • Foreman
    Foreman Member Posts: 30
    Riser Insulation??
    Should risers be insulated? My 2nd floor riser pipes are exposed on 1st floor as they go up. If I Insulate it, then it wouldn't match my couch, anyone else with this dilema?
  • Brad White_148
    Brad White_148 Member Posts: 14
    Is your couch
    constructed of Schedule 40 carbon steel pipe?
    Unless that is the case, I respectfully submit that they do not match now :)
