small chiller/heater for radiant bed
Brad White_9
Member Posts: 2,440
$700 is not a lot, so this is what I would do:
Buy a small electric hot water heater (1500 W point of use type), with an expansion tank, circulator and fittings. You can get all this for about $300. (Heater is about $150, circulator about $80, expansion tank -Watts #5- runs about $25, plus valves and fittings.)
Set up your Pex-Al-Pex or regular O2-barrier PEX as you need to (too much to get into here). If you can get your heater with a rheostat variable controller, even better.
That is your heat.
Cooling in my estimation is not possible using machinery in that price range. (If money were no option, a nice Filtrene unit at $6,000 would be ideal :)
For cooling, I would use the same heater/hydronic setup but instead of using the heating element, bleed in/drain off domestic water to maintain temperature. A good thermostatic bulb valve can maintain temperature. Key to me would be to keep the water "cool not cold" above the room dewpoint to avoid sweating. Provided of course that this meets your temperature criteria where it counts.
This will waste water, but the trade-off is unaffordable first cost and energy cost associated with that.
My $0.02
Brad
That is your heat.
My $0.02
Brad
small chiller /heater
I'm trying to build an massage table for a group of handicap people. I'm a senior at umass lowell and I'm looking to do radiant cooling and heating (W/ vibration) on a leather table. The main problem is finding a small unit to cool/ heat the water(under $700). Thank you for your time everyone.0 -
One thing I might ad
Vibration and any inter connecting piping, be it flexible or the like do not mix. You are asking for a leak. I am sure someone else might may be able to point you in the right direction,...Sorry.
My .02
Mike T.0 -
How Long...
How long would the "cooling" sessions be?
I am toying with an idea similar to the method used to make ice cream, believe it or not.0 -
So, Eugene,
Are you thinking a foot-crank bicycle arrangement, rock-salt brine solution, powered by the person on the table? You devil you!
That is almost... Swiss.0 -
Hmmmmmm
No foot crank.... but a rock salt brine yes...
Kind of like the eutectic plates used on truck refrigeration systems.0
- 109 Chimneys & Flues
- 975 Plumbing
- 386 Solar
- 17 Recall Announcements
