RF Thermostats
Chuck Shaw_11
Member Posts: 4
Thanks for the information.
Chuck
Chuck
RF Thermostats
I am working with some one who has a very old house, and a very tight crawl space, and has never had a heating system. She wants 4 zones, but the low voltage wiring would be a nightmare, are RF thermostats available (for remote mounting), if so, what brandname or working name. Has anyone used a brand that they are fond of. Any information would be great.
Thanks,
Chuck0 -
You rang?
Here are two options.... At the very least, Totaline and Honeywell make some. The Honeywell base station can handle up to 3 thermostats, which would make it a less expensive option than the totaline, which seems to need one receiver for every transmitter. HTH.0 -
Honeywell it is....
I was thinking the same thing.... They are more expensive, but if the access is impossible, you have no other choice.
Mike T.0
- 167 Indoor-Air Quality
