RF Thermostats
Thanks for the information.
Chuck
  • Chuck Shaw_12
    Chuck Shaw_12 Member Posts: 4
    RF Thermostats
    I am working with some one who has a very old house, and a very tight crawl space, and has never had a heating system. She wants 4 zones, but the low voltage wiring would be a nightmare, are RF thermostats available (for remote mounting), if so, what brandname or working name. Has anyone used a brand that they are fond of. Any information would be great.
    Thanks,
    Chuck
  • Constantin
    Constantin Member Posts: 3,796
    You rang?
    Here are two options.... At the very least, Totaline and Honeywell make some. The Honeywell base station can handle up to 3 thermostats, which would make it a less expensive option than the totaline, which seems to need one receiver for every transmitter. HTH.
  • Empire_2
    Empire_2 Member Posts: 2,340
    Honeywell it is....
    I was thinking the same thing.... They are more expensive, but if the access is impossible, you have no other choice.
    Mike T.
