smart boiler, DHW, coil,and infloor zones
Eugene Silberstein 3
Member Posts: 1,380
You might want to repost this up top as it might get overlooked down here.
thermic valves,zone valves, mixing valves ,circs......
Are thermic bypass valves always included in boilers systems manifolds or just when using condensing cast iron boilers? Hi, I am designing a 5 zone system w/3zone infloor, fan watercoil, indirect DHW, on a new Buderus 125kbtu boiler w/ Logistics brain. Am gettin conflicting advice on whether to use mixing valves to each infloor zone, whether to use individual circs or a main circ plus 1 circ and individual zone valves and just how to prioritize the DHW.(the brain says it has the circuitry for this) Any input to shed more lite on the subject? Plus it all needs to come together on the wall like a work of art(demanding client even painted the wall for mounting all the manifold systems) STormin0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 112 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
