Radiator BTU
Yuri
Yuri Member Posts: 2
Where can I find information how to calculate how many BTU 1 rib of cast radiator output.
  • Steamhead (in transit)
    Steamhead (in transit) Member Posts: 6,688
    Depends on the \"rib\"
    which is known as a "section". There are many different types- can you post some pictures here?
    Also depends on whether this is a steam or hot-water system.
  • Yuri
    Radiator is water radiant radiator (24" high and 6" deep)
  • bill garnett_2
    bill garnett_2 Member Posts: 21
    EDR
    You could calculate 5 sq ft per section (conservatively)multiply that by 180 for water and for steam use 240 x 5 x # of sections, some swag involved in this equation
  • Buzz G.
    Buzz G. Member Posts: 61
    Don't you need to know the temp at which the water will be circulating before you try to determine the potential output of a radiating body? For steam you always assume it is 212 or a little over but water is widely variable as to the temp used when it circulates.
  • Buzz
    The sq.footage(capacity of the rads output) should be known, then Yuri can calculate the water temperature it needs to satisfy the room(its going in) H/L requirement. There are tables for this too. He may be able to use a smaller, or larger rad, at this water temperature to meet the demand, and maintain continuity of the circuit, but the EDR must be known first.
    Hopefully he did his homework, to match-it with any other rads(if any) on this circuit! :-)
    Dave
