leaky furnace
John_136
Member Posts: 4
I came home on sunday night only to find the downstais steaming up with the hot Water all over the place. With a little bit of investigation , i find out that the h2o was coming from 2 places.1 from the pressure valve and 2 a pipe coming out of the furnace. I manage to shutoff the water, replace/ rebuild the pressure valve( pick one up at the local home improvement store and replaced the gasget and the ring and bolt) that seem to stop the water coming from there. But when i turned the water valve back on, It is still leaking What gives? is there an " easy reset switch" somewhere? At least that what I'm hoping Please help.
Boiler system is a weil mclain unsure of the install date.
I came home on sunday night only to find the downstais steaming up. Water all over the place. With a little bit of investigation , i find out that the h2o was coming from 2 places.1 from the pressure valve and 2 a pipe coming out of the furnace. I manage to shutoff the water, replace/ rebuild the pressure valve( pick one up at the local home improvement store and replaced the gasget and the ring and bolt) that seem to stop the water coming from there. But when i turned the water valve back on, It is still leaking What gives? is there an " easy reset switch" somewhere? At least that what I'm hoping Please help.
Boiler system is an weil mclain unsure of the install date.0 -
You need a pro
try the Find a Professional page of this site. There are several possible causes and it will take a pro to fix it corrrectly.
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 971 Plumbing
- 386 Solar
- 17 Recall Announcements
