Need insight on boiler manufacturers
[Deleted User]
Thanks much!
I will be replacing my hot water boiler and have received information and quotes from a few professionals. I have the glossy brochures for various high efficiency hot water boilers that describe the features and functionality, but I don't have a good feel for the quality and reliability and other related issues. The high efficiency boilers under consideration are the Triangle Tube Prestige, the Munchkin, and the Lochinvar Knight. Any insights are very much appreciated. Mike0 -
good list to choose from.
Good Choices, as Weezbo said
Assuming these are to be installed by contractors, make sure they have the training to be able to properly set up and service the boiler.
You can do a Wall search on the names if you would like to get a feel for the boilers.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
