ventless propane fireplace
JackFre
JackFre Member Posts: 225
For replacement heat I'd recommend the Rinnai Energysaver. If you go to www.ductlessheat.com you can view the product and do your own heat loss. You will not be disappointed. Do not oversize the unit. Depending upon the size/configuration of the house a mini-split A/C. Wait until spring and all the inverter based 21 seer units will be out.
  • Jim_63
    Jim_63 Member Posts: 1
    Ventless propane fireplace heating whole house
    I'm buying a place in a small town in California that has a ventless propane fireplace as it's only source of heat. Using a ventless fireplace is illegal in california so I'm wondering what a good substitute would be? Would a standard wall heater be a good alternative? Is electric baseboard heating too expensive?
    Thanks,
    Jim
  • Joe Brix
    Joe Brix Member Posts: 626
    Direct vent
    wall furnace or fire-place. Only you and your electric bill can decide. Need AC? What about a heatpump? Maybe a ductless mini-split for a small open floor plan house.
  • Steamhead (in transit)
    Steamhead (in transit) Member Posts: 6,688
    How big
    is the house? Does it have a basement? Where in California?
