Reverse thread bushings
Big Ed
Member Posts: 1,117
You may want to double check ,but the only radiators that I know used reverse threads were "steam only" radiators made in the early 1900's... They used oneway nipples to pull in the sections.Just the lower sections were attached .
I am converting some radiators from steam to hot water & I need a couple of 1-1/2" LHT x 1" ST black bushings. Is there a source for this outdated fitting?0 -
L&R bushings.
Ya, I got a few, most rads-on-feet on my side of the border were usually tapped LH, I`m not sure if you can still get them here though, I never looked. I usually use L&R nipples and reducing 90`s.0
- 167 Indoor-Air Quality
