CO detector placement
Mark Hunt_2
Mark Hunt_2 Member Posts: 80
Put one in your bedroom on top of your dresser.
Alarms in the basement will probably not wake you up if they go off and I can just about guarantee that your CO Experts alarm will go off in the kitchen unless your stove is vented to the outdoors.
Hope this helps.
Mark H
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=238&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • jim_14
    jim_14 Member Posts: 271
    need advice on where to place CO Detectors
    Got a washer/gas dryer on 2cnd floor near all bedrooms, so thats a no brainer Im putting a CO Experts near there.
    Main floor where kitchen/DR/LR are located -Im not sure if I need one there. Dont they say not to put one near a gas stove? What do you think??
    Basement- got one there already near boiler/HWH in addition to a fresh air vent thats always open near that stuff just to be safe.
  • jim_14
    yeah i thought the kitchen area
    would be a bad idea.
    Why not in the hallway? I have 3 bedrooms on that floor
  • Rookie_3
    Rookie_3 Member Posts: 244
    Jim
    I believe the ideal height for a CO detector is approx. eye level, I think thats why Mark suggested putting one on top of your dresser.
    Dan
  • Mark Hunt
    Mark Hunt Member Posts: 4,908
  • Jim Davis_3
    Jim Davis_3 Member Posts: 578
    If you have only one alarm the bedroom area is always the best. Checking levels in the kitchen are very important when using the oven. Could indicate the oven needs to be adjusted. Unfortunately most appliance companies do not know how to do this. Your alarm will start beeping at 25 ppm and if you have this level in the kitchen it is time to start ventilating and get the oven checked.
