Refractometer question (Starch)
John Starcher_4
Member Posts: 794
...my new refractometer bought from our friends at Rhomar. Don't have a clue what I'm doing with it!
I took a sample from a customer's boiler, to verify the antifreeze condition. When I use the refractometer, It is showing me a "brix" scale of 32, which is the equivalent refractive index of 1.3847.
Now, how do I use this to determine the % concentration of my antifreeze?
Thanks,
Starch
Thanks,
Starch
Thanks, Mark.....
...lots of usefull info on there.
I talked to Rhomar today (it was late last night when I was fooling around with it, and their office was closed), and it turns out they sent the wrong refractometer to me!! A replacement is on its way that will read antifreeze protection level directly.
Starch0 -
John
Our fault and new one is on its way. The readings you will see are direct. It is easy to use.0 -
Thanks, George......
...Your office person was very helpful, and she told me you'ns guys would send a new unit asap.
Always sump-thin', ain't it?
Starch0 -
SUGAR SHACK
Yeah, Brix is a check of sucrose content usually used to check post mix pop machines for correct mix.
I have a slightly used glycol refractometer that I no longer need. Make me an offer.
John0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
