Refractometer question (Starch)
...my new refractometer bought from our friends at Rhomar. Don't have a clue what I'm doing with it!
I took a sample from a customer's boiler, to verify the antifreeze condition. When I use the refractometer, It is showing me a "brix" scale of 32, which is the equivalent refractive index of 1.3847.
Now, how do I use this to determine the % concentration of my antifreeze?
Thanks,
Starch
  • Answers to your questions...
    http://www.misco.com/products/BRX15.html
    I googled brix scale.
    ME
  • John Starcher_4
    John Starcher_4 Member Posts: 794
    Thanks, Mark.....
    ...lots of usefull info on there.
    I talked to Rhomar today (it was late last night when I was fooling around with it, and their office was closed), and it turns out they sent the wrong refractometer to me!! A replacement is on its way that will read antifreeze protection level directly.
    Starch
  • George_10
    George_10 Member Posts: 580
    John
    Our fault and new one is on its way. The readings you will see are direct. It is easy to use.
  • John Starcher_4
    Thanks, George......
    ...Your office person was very helpful, and she told me you'ns guys would send a new unit asap.
    Always sump-thin', ain't it?
    Starch
  • JohnWood1
    JohnWood1 Member Posts: 63
    SUGAR SHACK
    Yeah, Brix is a check of sucrose content usually used to check post mix pop machines for correct mix.
    I have a slightly used glycol refractometer that I no longer need. Make me an offer.
    John
