squeaky Raupanel
EdyLogicMstr.
EdyLogicMstr. Member Posts: 58
Funny guys.
"I'm the only one Who's ever had an issue." How many times have we heard that? I'm use to it now.l Then,,, guys t that hide behind names like Squeaky instead of confronting me ,,, can well you know,,, Kiss My ****!
FYI; the noise from the QT/CP's went away after I pulled them up at great expense. I now use a bead of PL 200 and apply the panels to the sub-floor. I HATE using this system but it has its place.
Silence
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=296&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • I have a client with raupanel floor system, and a small patch of the floor speaks when walked on.
    I've heard of this before but never heard the explanation or fix.
    I'm looking at a very large Raupanel project right now... and I want to make sure this does not happen.
    Any ideas?
  • ScottMP
    ScottMP Member Posts: 5,882
    ask
    Gary Wallace, I think he's had alot of experience with this.
  • that was quik trak ;)
  • Brad White_9
    Brad White_9 Member Posts: 2,440
    It was quick-trak.
  • stephen_4
    stephen_4 Member Posts: 22
    is the finish floor nailed down yet?
  • It is in the old job but it's a small area not in major traffic and the client is not upset. I just want to make sure it does not happen in the future. Sounds like you have an idea?
  • Josh_10
    Josh_10 Member Posts: 786
    I have completly switched to Raupanel for my company. I used to install alot of quicktrack for a former employer. At any rate I haven't yet had a problem with Raupanel. What I do whether it is quicktrack or Raupanel is throw in a little silicone on the edges of the track between the joints. Could be the cause for succcess.
  • Hmm, that's an intriguing idea. Thank you very much Josh!
  • Josh_10
    Glad to help my friend!
  • EdyLogicMstr.
    Who does this?
    Squeak & Wary Gallass,,,, ?? Who the??? and WHY?
    Use PL200 under the QT/Climate Panels' & the noise goes away. Another step and expense but hey,, it's finally silent. This step is not approved by the Mfgr. but they also said; "this seems to work."
    Haven't used Raupanel yet but I'm sure it"s not much different than ThermoFinC .Break out the Crisco™;-)
  • Josh_10
    What's PL200? Just curious. At any rate Gary I am really impressed with the Raupanel right now. Like I said I haven't had any problems yet. The reason I really love it is because of the super low temps you can run as aposed to QT. Don't get me wrong I love Wirsbo but I can't help but really like the Raupanel. I think everyone should try it. You get the efficiency of light weight cement and the response of radiant ceiling heat. Just rockin the boat...
  • Plumdog_2
    Plumdog_2 Member Posts: 870
    PL200
    is little brother of PL400. (it is what carpenters put on the floor joists before nailing down the subfloor).
