Old forced hot air natural gas furnace problems.
Jeff Lawrence_24
Member Posts: 593
Probably a safety tripped.
If it is, it tripped for a reason. You need to find out why.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=159&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Old furnace has attempted to die.
My furnace is not firing up. The pilot light stays on. I have bypass the thermostate and the furnace do not light up. I am able to turn on the fan manually. There appears to be electric getting to all parts. The one thing that I keep coming up to is a valve type device that has the main and pilot gas coming though it, it is also the part that has a knob that allows me to turn the pilot on and off. This is a robertshaw part that I am told that the replacement part is 700-406 Is there any way to check the old one before I replace it.0 -
Check your transformer.
TJust a guy running some pipes.0 -
baso switch or saftey gas valve?
If it is a baso switch, there is a push button reset. If it is a saftey gas valve, it is prolly shot. Disconnect the t-stat at the t&t at the gasvalve and jumper out T&T. If it fires, it is not the gas valve, if it does not fire, the gas valve is bad. It also maybe labled T%TV. In anycase, it is where the t-stat wire connects onto the gas valve. Remember to disconnect the t-stat wires, or it will blow the heat anticipator on the stat and ruin it0 -
furnace not firing
I did check the transformer and it is okay . In 1973 LILCO had replaced the gas valve. I did jump the stat and nothing.0
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 970 Plumbing
- 386 Solar
