Short Cast Iron Baseboard
The stuff you got... is it 7 inches or shorter? How can I get in touch with you?
Geoff
  • Geoff Mirantz
    Geoff Mirantz Member Posts: 2
    I have a client restoring a very old house and wants to use cast iron baseboard that doesn't exceed 7 inches in height. I have only been able to locate equipment in the 9 to 10 inch range. I'm in New Hampshire and these damn restorers are pretty stubborn. Anyone know who or where I might find some short cast iron?
  • got a whole
    Got a whole bunch of them ( base-ray from Burham) problem is I'm in west of Chicago suburb...
  • Al Corelli
    Al Corelli Member Posts: 454
    I may have access to some used Burnham stuff.
    A customer has it in his basement, uninstalled, some new, some used.
    How much do you need? Which end covers or other items?
    I'm in NY just above the City.
    Not to blow your other deal, just in case it doesn't go through.
  • the 7A burham radiators
    Took them out of a home before the teardown... All been painted.. Yeah they are 7" height and so u know that they are at reduced heating capitcy of 9" high counterparts.. Hope ur remobler knows that... Will needs much more length for same heat output, how much u need?
