Thermo set at 50 degrees and heater starts up and cuts off in a
How long u been having the problem? Is the heating anicaptoir(sp) set, if the thermostat been "shorted", its will cycles erraticly...
Heater starts up and cuts off
Thermo is set at 50 degrees and it will start up and run for a few seconds and stop then repeats0 -
it oil heat
it oil heat0 -
what kind
What kind of thermostat u have and is the heating ancicaptor set for ur heating unit?0 -
thermostat
honeywell
dial on top
thermostat on bottom0 -
Do you have....
Taco Zone valves? kpc
fixed
It seems the eye is not seeing the flame0 -
Start out with a digital set-back battery op thermostat Cheap, easy, required by title 24, and effort not wasted even if it's not the problem. If you want to test the old one just turn it up to max when it's short cycling and see if you get a long burn out of it.0
- 167 Indoor-Air Quality
