WHERE DID IT GO?
bob_46
Member Posts: 813
Unless you pick up heat in the condenser drain line or the receiver shell you must be losing it to pressure drop.
Where did it go?
Dear Professor,within reason energy cannot be created nor destroyed but only converted to another form.So ,subcooled refrigerant[8*-10*] leaving the condensing unit goes into a reciever tank where there is a saturated condition.And with a saturated condition there is no ,none ,nada subcooling.So WHAT HAPPENED to the subcooled energy? I need to sleep so PLEASE be my NITEALL!Thank You!0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
