i valve
kevin coppinger_4
Member Posts: 2,124
used ths 3 way/ 4 way valve yet? like it? not so much? would you use it again? problems? kpc
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=323&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Kevin, these are great valves....
the i series S 2 way i use for modulating my temps back to the boiler across a by pass,the three ways are an excellent valve however of these valves i have only installed the I series R, the four way I series R is relatively new and the Taco guys would not put their personal display one up for auction....however*~/:)
we have one installed and some snow and ice is still on the ground around here and it seems to work fine.
the RMB's are an excellent tool for the habby hydronisist,as it the X Block. The V series pumps are another way to roll. The ESP that i Heavily installed are quite conviently conspiring against the oil companies
so now i can offer, upgrades to, the i series R for the replacement head.... 0 -
we have about
We have about seven of them out there and are very happy.
Scott
- 167 Indoor-Air Quality
