MA location for sandblast/paint hot water cast iron rad?
Tim Smith_9
Member Posts: 7
You might have already tried this, but if you go to Google maps and enter a type of business and a zip code, you will get local results. For example, you can just enter "Powdercoating 01234".
Seeking MA location for sandblast/paint hot water cast iron rad
Hi,
Any north of Boston, MA locations that anyone can point me to for this type of service?
I have a hot water cast iron (ornate) radiator that I'd like to get sandblasted/primed and powdercoat or painted. The system has to be drained to fix a leak, so it'll possible to have the radiator taken to a place that can perform the sandblast/paint work.
Thanks in advance!
Lee0 -
call an..
local auto body place. Also you could try a pressure washer w/ a fine tip.0 -
Will an auto body place think I'm nuts?
Thanks kpc.
If I telephone a local auto body place and tell them I want them to sandblast and paint a home radiator, will they think I'm nuts?
OK, so I'm a little afraid of looking like a nut. :-) But I'm willing to look like one to have it done cleanly.0 -
Sand blasting
we send are radiattor to a sandblasting comapany in Oxford Ma. Once completed we go down to Webster for the finish
If you need names and address email me
refinishing
I've had great results with Central Mass Powder Coating in Clinton (okay it's more west than north of Boston). They should be able to handle most any job of this nature.0 -
preprite
Try Preprite in Tewksbury
495 Woburn St
Tewksbury, MA 01876-3434 978)453-0006
http://www.preprite.com/0 -
Radical radiators in Everett. Talk to Joel. 617-733-7163. He does that.
Ya know, Radical Radiators was the first place I tried, because I had saved a clipping from the Boston Globe about them. I left a phone message and sent email, but didn't get a response back.0 -
Nelson, that is a very nifty trick about Google maps and the business/zip code. It works pretty well--I'm going to remember that.0
