Pex tubing manufacturer
kpc_75
Member Posts: 37
an O2 barrier? I have heard of it. Same type as Zurn or Quest. If it has the O2 barrier it probably ok. FWIW...I would use Uponor/ Wirsbo if it were my house.
I have pex tubing made by "Everhot" ready for installation in a slab on grade for a radiant heat system. Nobody in our area has heard of the maker, although the supplier and the companies website lead one to believe that it is a good quality product - appears to meet ASTM and DIN standards, etc. Just looking for someone that has used and/or heard about this product as it is not (apparently) a widely recognized brand-name and I was recently given a heads up on some inferior pex that has deteriorated inside a slab. We're set to pour in a couple days.
Thanks!
Craig0 -
I doubt they make the tube, I think they are just an importer. This tubing is commonly sold on ebay as well.
Oddly enough, the company is located right here on Long Island.0 -
Everhot/Rifeng
This tubing is made by Rifeng Systems. http://www.rifeng.com/index.asp
They also Private label Pex Al Pex for other US manufactures. Kevin0
- 87K THE MAIN WALL
- 112 Chimneys & Flues
- 106 Geothermal
- 979 Plumbing
- 387 Solar
